The first vent line I had to do was one no-body seems to ever do or talk about. Gas tank vent
I removed my charcoal canister and vents a long time ago. After that, my gas tank vent just ended on the passanger frame above the rear axle. So I yanked it out and bent up this brake line to go from the center of the tank vent, up to behind the gas filler door:
Drilled a 1/4" hole
Feed line threw hole
put 1" of rubber hose to keep it from falling out.
I'll do more later
Drilled a 1/4" hole
I'll do more later
