1 - 11 of 11 Posts
Discussion Starter #2
So this is a 1978 Bronco XLT Ranger. IT was it California since sold. No Rust, The interior is crap. It is mostly Stock with the 351M and C6.
I have major plans for her.
  • 17MY F150 Coyote swap with 6R80 (only 20K miles..) from a junkyard
  • 4 BDS lift with rear sping, ordered already
  • 35 in all terrain tires. I am not sure how much bigger bigger wheel than the 15 in I will get. I will go close to 12 in wide ...6R80 to NP205
  • PBH Control pack, speed drive and fuel system
  • New Cooling, AC, Heat ... still looking, Vintage air does not have a kit for 78/79 Broncos. Please make recommendations
  • I will take apart and do a full Restoration in my Garage. I can take the Top off and the front clip. I will have to be create to remove the body.
  • I will paint it myself, black with likely a free-wheeling package, not sure yet.
  • I will keep keep the NP205 and use an F-150 /mustang floor sifter
  • She does not look great on the inside, so she will need seats, carpets etc...\
  • I will use chassis saver for the frame
  • I am looking for a NP205 to 6R80 adapter ... no luck so far ..
Yo 78BroncoManiac,
Welcome and congrats, it looks great!
Some info for you:
1978 Bronco Dealer Brochure via Indybronco
1978 Bronco Emission Component Location Diagrams via 78brncoxlt
1978 Ford Bronco & Truck Wiring Diagrams by Ford via Bronc Mom @ https://drive.google.com/file/d/15KEp-dmAewg_76EfeIPysZGftmGiO7fN/view
1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual via topsig (Ziggy); similar to 78.
1979 Wiring Schematics, Connector Pin-outs, etc by Ranger429 @ https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/223050-79-wiring-schematics.html
Similar to 78
Bubba's M-Block Ford V8 Workshop by Dave Resch @ Bubba's M-Block Ford V8 Workshop
MANY 78 Parts Break-Out Diagrams by Indybronco (Lula Mae) @ pictures, videos, and sounds | SuperMotors.net
78 351M/400 Engine Exhaust Emission Control Information Decal & Timing by member grovermyson @ https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/505882-timing-do-i-need-do-anything.html
C6 Auto Transmission, if equipped, Description & Operation, Adjustments, Diagnosis & Testing (partial), Disassembly & Assembly, Parts Break-Out Diagram, Hydraulic Control System Diagram, Removal & Installation & Specifications @ https://redirect.viglink.com/?format=go&jsonp=vglnk_155464716156516&key=6ed47b392b9edfe394b9e89b72717104&libId=ju70qeuf01000bgv000MAb4isjltc&loc=https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/210246-c6-rebuild.html&v=1&opt=true&out=http://www.thedieselfiles.com/Ford/C6%20Automatic%20tranny.pdf&ref=https://www.google.com/&title=C6 Rebuild - Ford Bronco Forum&txt=Description & Operation, Adjustments, Diagnosis & Testing (partial), Disassembly & Assembly, Parts Break-Out Diag...
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ https://web.archive.org/web/20130419152159/http://www.broncocity.com/66-81manual.htm
Ford Shop Manual Diagrams: 1978-1979 Full Size Shop Manuals, partial @ https://broncograveyard.com/rt-1273-technical-diagrams-archives.html
My Tablet takes too long to download, so try the first in this list as long as you have Adobe Acrobat 9 installed. Let me know if the downloads are worth the effort.
Includes:
Wiring Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Rear Lights Diagram
Motor Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Air Cleaner Diagram
Chassis Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes '78 Brakes Diagram, Gas Tank Setup Diagram
Body Manuals & Diagrams Download PDF This complete manual for the 1972-1979 Ford Bronco Includes; Upper Body Diagram, Front Clip Diagram, heater Ducts Diagram, Tailgate Diagram, Console Diagram, Front Clip Diagram, Grill Setup Diagram, Heater Controls Diagram, Interior Trip Diagram, Rear Sheetmetal Diagram, Tilt wheel Diagram, Tire Rack.
Order a Ford authorized repair manual other than the EVTM, either a Bishko or a Dave Graham from rockauto.com in Literature section or other source. If it's a CD, ask if it will run on your device.
For any Bronco issues or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Build section that requires a 30 post count & Bronco and Ford Parts/Accessories (75 posts required to view).
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our Forum faqs @ https://www.fullsizebronco.com/help/faq/
Includes for example:
How To Upload Images To Posts & How to Use Search
See more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) @ https://www.fullsizebronco.com/forum...ech-links.html
Look at some Technical Service Bulletins @ http://www.bbbind.com/tsb-wiring-diagrams-database/
Look through our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
Al
Addicted to Junk
Welcome to FSB! Looks like a beaut from the outside.
Did ford change the transfer case mounting flange from the round 6 bolt?
Thank you for all the great links. I updated my profile and signature (for now)
Here my Tcase. I am swapping it with the Tcase that came with the 5.0/6R80 thow
Reactions: canuckistan97
Addicted to Junk
That old transfer case is a sought after NP205. They are nearly indestructible due to the 100% iron and steel construction. The only downside is the whimpy 1.96:1 low range ratio. You could get 2-300 bucks for it, as is.
1978 Bronco Ranger XLT, 12V P-Pump Cummins, ZF5, Dana 60 Front, Sterling 10.25 Rear
Looks amazing. Sounds like a badass build. Excited for some updates!
1 - 11 of 11 Posts
