How old are you? And your parents... don't even get me started, lol :twak
About the trim and stuff - do you have any junkyards around you, the "U-Pull-It" type? That's a great way of learning things, I destroyed the roofs of two Townie Cars before I figure out how to chop mine, after two years of demolishing other Townie Cars so I don't go stupid on mine when it needed work.
I've asked! I just dont think I have enough time.... We do have a u-pull-it type junkyard down in the "ghetto" (lol) area of gresham. I could check that out for some parts I may need.
The parts I will most likely need for the outside of my truck are
Drip rail moldings, lower t-gate molding, tail light moldings, wheel arc moldings, grill insert, and possibly the outter grill shell. The side moldings are in fair shape, one has a hunk of rubber missing, is there anyway to rip the rubber out of those and replace it?
Also I heard on Trucks "Launching Das Bronco" that you can clean up anodized aluminum trim by using oven cleaner... would you guys recommend doing that? Spray, let it sit, wipe off, polish w/flitz or mothers...?
I can't see spending 5k on a paint job for a 4x4.....one trip off-road, or one trip to the grocery store later, your paint job will be fawked.
get with your buddy and try to spray it yourself......if you mess up, you can always re-do it.practice makes perfect.
Ya this is true. I worry about that. I'd be doing chip guard to help with the rocks and as far as parking lot, I would be parking at the back... I'm a stickler for perfection on my truck and I really dont want it getting effed up right after I paint it.
Whoa. What happened to the list of 400 parts we put together?
Don need no 460.
You can prep the steel yourself & paint it with epoxy primer. Get some do it yourself body paint books & you & your pal get busy wet sanding it. Tackle small areas - so as to be able to finish & seal & then move on to the next one. Tailgates are a dime a dozen & because they don't drain water they ALWAYS rust. Some more than others. Take it off & strip out the guts. Will teach you how the power window works.
You're tripping. Take it slow & conserve cash.
I still have that parts list and would really like to do it. If I can get this paint outta the way with my friend, I'd be able to do both, possibly both over summer which would be kickass. Once the horse trailer is sold I have a couple other things I can get rid of. The 400 will be incredible once it is done. That motor has run good for so many years I'd hate to see it take a sh!t. If I do the pj with my friend then the motor is very likely to happen. I'm going down there today after school and talking with his dad about the trade for trade deal.
And the 460 I was talking about was an
extremely good deal and under warrenty. It was in a 78 that was beat to shit but it has new brakes, heater core, water pump, and a brand new 460 with under 5k on it under a warrenty from the place he had it built. So he had all the brackets I would need and all the 460 swap mount brackets which was the only reason I was interested. He placed an ad on portland craigslist if anyone around here needs a 78-79
