So I just ordered new steering linkage and some new Moog CC820 springs for the truck. I was also considering replacing the radius arm bushings (again, got cheapies the first time and they have already failed) as well as sway-bar bushings. anything else I should do while I am at it?
axle pivot bushings
I have never done those before...are they difficult to replace?
Yo MIKEY
see info the axle pivots in my site @ http://www.broncolinks.com/index.php?index=332
Including;
Bracket Removal & Installation, Parts Break-Out Diagram & Torques in a 96 from 1996 F-150, F-250 4x4 and Bronco Workshop Manual
Source: by Ford
Bushing Replacement in a 92
Source: by Richard C (Bigric, Money Pit) at FSB
Bracket Replacement in a 94
Source: by Chris T (“1 EYE”) at rmftc.com
Rivet Removal in a 95
Source: by gretna1970 at FSB
etc.
and for other steering part info LINKs, see http://www.broncolinks.com/index.php?index=45
Includes;
Radius Arm
Stabilizer
Tie Rod & Ends (TRE)
Track Bar
Diagrams such as Steering Linkage
The steering linkage, which connects the steering gear sector shaft arm (3590) to the front wheel spindles (3105), is composed of a steering sector shaft arm drag link (3304) and tie rod end (3A130). The steering gear sector shaft arm transfers the steering gear (3504) movements through the steering sector shaft arm drag link and tie rod end to the right and left front wheel spindles.
The F-150, F-250, F-350, Bronco and F-Super Duty Chassis Cab steering linkage have adjustments in both the tie rod end and the steering sector shaft arm drag link.
Item Part Number Description
1 3A131 Tie Rod Ball Stud
2 3310 Front Wheel Spindle Tie Rod Adjusting Sleeve
3 3304 Steering Sector Shaft Arm Drag Link
4 � Drag Link Ball Stud
(Part of 3304)
5 3A131 Tie Rod
6 N800895-S56 Nut
7 3590 Steering Gear Sector Shaft Arm
A � Tighten to 70-100 Nm
(51-73 Lb-Ft)
And for SUSPENSION; ball joint, springs, etc. see my site @ http://www.broncolinks.com/index.php?index=46
Front Description & Operation, Diagnosis & Testing, Removal & Installation, Specifications & Special Service Tools & Equipmentin a 96 from 1996 Bronco Workshop Manual
see diagram f2856p below
1 3B008 Steering Rod Link
2 800895 Nut
3 642569 Cotter Pin
4 380288 Steering Cap
5 801079 Bolt
6 3002 Axle
7 5019 Front Crossmember
8 620604 Nut
9 802073 Nut
10 802114 Bolt
11 802246 Bolt
12 802073 Nut
13 620604 Nut
14 801079 Bolt
15 3K090 Front Axle Bearing Bracket
16 802210 Bolt
17 3B183 Radius Arm Bracket
18 800937 Nut
19 34922 Nut
20 379572 Washer
21 2B463 Shield (RH Only)
22 3A184 Outer Insulator
23 3B244 Spacer
24 3B203 Front Insulator
25 3B186 Front Retainer
26 3405 Radius Arm
27 N805348 Nut and Washer
28 18198 Insulator
29 5B315 Spring and Shock Bracket
30 18124 Front Shock Absorber
31 620468 Nut
32 620469 Nut
33 18126 Shock Bracket
34 805033 Bolt
35 3405 Radius Arm
36 605921 Bolt
37 58740 Bolt
38 3B446 Front Axle Radius Arm Bracket
39 40954 Bolt (2 Req'd)
40 390678 Stud
41 5B316 Lower Spring Seat
42 5414 Front Spring Insulator
43 5A349 Retainer
44 388833 Nut
45 5310 Front Coil Spring
46 5A333 Upper Retainer
47 40949 Bolt
A � Tighten to 71-100 Nm
(52-74 Lb-Ft)
B � Tighten to 18-24 Nm
(13-18 Lb-Ft)
C � Tighten to 34-46 Nm
(26-33 Lb-Ft)
D � Tighten to 60-81 Nm
(49-59 Lb-Ft)
E � Tighten to 434-461 Nm
(320-340 Lb-Ft)
F � Tighten to 26-34 Nm
(19-25 Lb-Ft)
G � Tighten to 326-352 Nm
(240-260 Lb-Ft)
H � Tighten to 94-134 Nm (70-100 Lb-Ft)
J � Tighten to 34-46 Nm
(26-33 Lb-Ft)
K � Tighten to 113-153 Nm (84-112 Lb-Ft)
L � Tighten to 213-287 Nm
(157-211 Lb-Ft)
M � Tighten to 104-148 Nm (77-109 Lb-Ft)
