1 - 10 of 10 Posts
But its a kind of whistling when you suck air in, not blow it out. Its intermitent, and does get a little louder with a higher idle. It sounds like its coming from the front of the motor. Checked around, hard to tell where coming from. Anyone ever had this noise, sounds like a steam whistle from an old train, but not as loud, but loud enough to be heard while driving?
A little elf may have installed a supercharger while you were asleep last night. I would bet on it.
Can it do the theme song to The Andy Giffith Show? That would kick ass:rockon
If it does it while sitting still, how about vacuum lines, fan, intake tube, etc?
OOPS GIVE A DAMN IS BROKE
check your vac lines and check your fan and sure it turns freely. but more than likely it is a vac leak.
My EGR Valve whistles sometimes......I just lubed the shaft and it slides smoothly now! :hump :hump
OUT OF BUSINESS / M.I.A
Pulled codes on the F350 yesterday--- seems that both left and right engine banks were running lean. Started her up and slowly started jiggling all the air/vac hoses. Sure as shhit, a bad 3/8" ninety degree hose to the pvc. Found a similar shaped hose at Kragens from the Help rack (part #46001) for $4.00 and customized it to fit. Big difference right there...........
1 - 10 of 10 Posts
