Yo R,
As Mikey advised, post logo or name of the box's source here.
"The "MAIN KILL" is best if you store the vehicle for long periods and want to keep the battery from draining, or to allow a trickle charger to work. The disadvantage is that all the memories (PCM adaptions, radio stations, clock) will be lost immediately. NEVER turn the switch off while the engine is running.
The "STARTER DISABLE" will allow the engine to continue running after it's switched OFF, but won't allow it to be started. This will preserve the clock & radio memories, and confuse most thieves since every other electrical device will work normally. It will appear that the starter is defective.
"ANTI-THEFT" is even more confusing since the memory circuits will continue to function normally, but the ignition switch will appear to be defective. This configuration doesn't require a heavy battery switch since the starter relay only needs a couple of amps to work. This also requires the switch ON for starting, and then it can be switched OFF while the engine is running.
Another option for the Anti-Theft setup is to transfer the Alt & FB feed to the same side of the kill switch as the fuse link, which is effectively the same as the Main Kill, but without the requirement for such a high-capacity switch.
Wal-Mart & some parts stores now sell a Chinese knock-off of the Hella switch linked above for about $10. It's not worth it.
This diagram was created from this set of symbols using MSPaint" by Steve
Find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @
https://owner.ford.com; or @
https://vinrcl.safercar.gov/vin/ ... have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND
THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
To confirm current status, use this guide by jowens1126 @
https://www.fullsizebronco.com/foru...ruise-control-recalls-repair.html#post6530073
Note that the 93 recall is different than the 94-96 recall.
For any Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to view).
Please fill out your Bronco Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual), location info & major mods such as a Lift, etc. for better responses.
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our Forum faqs @
https://www.fullsizebronco.com/help/faq/
Includes for example:
How To Upload Images To Posts & How to Use Search
See more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) @
https://www.fullsizebronco.com/foru...-favorite-fsb-links-lots-lots-tech-links.html
96 Bronco-F-Series Workshop Manual (PARTIAL) via
1996 Bronco/F-Series Workshop Manual
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @
https://www.fleet.ford.com/partsandservice/owner-manuals/
96 Bronco Dealer Brochure @
https://www.supermotors.net/registry/3549/15947-2 ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @
http://www.supermotors.net/registry/2742/80431-2
Free registration for some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) same as by Ford @
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @
http://owner.ford.com .
➡ Try to take time to Participate &
VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @
https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
F.O.T.M Contests will be held in JANUARY, MARCH, MAY, JULY, & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
VOTE ASAP IN ONGOING F.O.T.Y. CONTEST⚠
