1 - 2 of 2 Posts
I have 79 f250 8 lug knuckles and out that i want to use on my 79. I would like to use the f250 knuckles to do high steer later on but need to know if the 79 bronco tie rods will fit the f250 knuckles. Have to do my ball joints so wondering if i can just install the knuckles now rather than doing it again when i do the high steer.
TIA
I can't say because I've seen 79 Broncos with both the mid sized and larger sized tapered studs. I don't know the exact dimension, but by mid sized I'm reffering to the stud with 1/2" threads and the threading is the same diamater of the smallest part of the tapered stud, just like what all the TTB trucks use. On the larger size the tapered stud has a shoulder about 1/32" on each side for a stud about 1/16" larger then the other. The only way to really tell is to remove the nut and see the size of the hole.
1 - 2 of 2 Posts
