1 - 2 of 2 Posts
Ok here is the problem....I have to put fluid into the clutch master cyl everyday, I am planning on changing over to a e40d in the spring but i have to get through the winter with the manual.
Any ideas on wher i would start to look for the leak or if anyone else has had this problem, all info would be much appreciated!
thanks in advance
check the slave cly. frist and just work you way up the line. to make finding it easier clean the whole thing with something brakeclean works real good the just look for new wet spots.
1 - 2 of 2 Posts
