1 - 4 of 4 Posts
300/302/351w PMGR "mini" Starter
An affordable solution for high torque, small case size starters to replace factory 70's style starters. Up to 4.5 times more starting torque, 50 percent weight reduction, and a much smaller case than your factory starter to reduce chance of heat soak from headers. Available for automatic and manual transmissions (c6 or np435) and is direct bolt in for 70s trucks with 300/302/351w
From 122.99
have you got a similar setup for the FE? I don't need one... but would be good to know where I can get a good, small one for a reasonable price.
my hedman long tube headers have cooked 2 regular ones already and while this last one is holding up pretty well, I don't expect it to last forever fitting that tight.
1 - 4 of 4 Posts
