1 - 4 of 4 Posts
Bolt on 9" Disc Brake Conversion Kit
For converting drum brake Ford 9" 5x5.5 axle to disc brake. Grade 8 hardware supplied with all kits.
(2) Disc brackets and spacers: 149.99
Aftermarket retainer required, factory will not work
(2) Disc brackets, spacers, and bearing retainers: 199.99
(2) Disc brackets, spacers, bearing retainers, bearings and seals: 299.99
(2) calipers, (2) rotors, (2) brakes hoses, (2) banjo bolts, and brake pads: 549.99
Upgrade to e brake calipers/springs/brackets/levers for an additional 250 with complete kit purchase: 799.99
Axle shaft wheel mating surface diameter will need to be turned or ground down approximately 1/8" to clear rotors. For use with axle flanges with 3/8" bolt holes. If you have a flange with 1/2" bolt holes please contact us to get required spacers.
1 - 4 of 4 Posts
