intresting
Grote part # 44890 is a flasher ment for LED's 1-2amp draw
Thanks RyanFireguy50 said:intresting
RyanFireguy50 said:no that flasher doesn't need dummy lights.
But if you are leaving the rear lights stock, you don't need dummy lights either.
you only need dummy lights in the brake circuits for the cruise.
what is the measurments of the stock housings and the LED lights you used?
Juggernaut89juggernaut89 said:Could i use these for taillights? how did u wire them so they light up when ur lights are on and get brighter when the blinkers on?
I may be the only dummy in this thread as I don't understand what dummy lights are. I bought these as sealed trailer brake/tail lights with 3 wires ready to hook up. All I did was hacksaw off the lid so to speak.juggernaut89 said:o, well will i need to get "dummy" lights? so the system doesnt think theres a bulb out?
LEDs draw less amps, but run on 12v so the system thinks theres a bulb out because they use less powerI assume they were engineered sealed to work just fine with regular 12 volt power.
Almost correctjuggernaut89 said:LEDs draw less amps, but run on 12v so the system thinks theres a bulb out because they use less power
85F15085f150 said:just a quick question, how did you secure the stock lens back to the grill...since you had hacked out the white studs the to nuts go on? is it possible to cut the led housing smaller to fit betweenthe to studs? i was thinking about something like this becacuse it seems like people never see my turn signals on :shrug
Too trueFireguy50 said:Pi$$ off people? LOL
Every time I turn the key to RUN, somebody is going to get pi$$ed somewhere.
It's tradition when I'm driving.
Full size truck, short wheel base, fast engine, birds eye view, sag PS pump.
It's alost the perfect sprts car
I ruined a 02 Cobra's day 3 months ago on the highway.
we could both go 95MPH, he could go faster, but was limited to 75MPH because he couldn't see around trafic.
I could see everything and left him way behind LOL![]()
