I bought a set of mounts from KahlKreations.com this summer and only recently got them mounted up. So far, they hold up well. I did kinda screw up the sizing of my light bar and had to come up with a set of extensions but I got it worked out. The thing I like about these mounts is that, even though they clamp to the rain gutter, the weight of the light is put onto the roof of the cab, rather than the gutters themselves. The gutters just keep the mount from shifting around. Holds up well at highway speeds too. Now I just need to figure out how to wire the damn thing up so I can use it
Fantastic, their mounts came put great !! I ran the wiring into the door jam -- with the door open there's a vertical rain gutter on th cab, I drilled a 3/8 hole (siliconed the hole later) and ran the wiring down to the firewall, then connected the dash switch and electrics.
Is that a pic of your truck? Does all that hardware really stick up like that? Can you cut it off? Is it stainless? Is there something under the side brackets to protect the roof paint?
That hardware was just what I had on hand to make it fit. It is not what the light came with. I do realize I need shorter bolts, but I'm waiting till I can get the light to work. They will be stainless. Right now, its a bunch of washers sticking out, but that will be remedied with a shorter bolt. And yes, there is a foam pad under the brackets to protect what's left of my paint.
Every light I have seen comes with mounts that screw to whatever you want to bolt it to. Why couldn't we just bolt it straight to the roof? Are you guys wanting to make it removable? Are is there some other reason for this? Just wondering.
I finished mine last week. I was a bit rushed, so they aren't perfect but they turned out pretty good and the actuator worked great for adjusting the angle.
Several reasons:
1) the roof is double-walled;
2) the roof is very thin sheet metal
3) the lights will shake from wind & bumps
4) the shaking will crack & tear the roof
I bought a set of mounts from KahlKreations.com this summer and only recently got them mounted up. So far, they hold up well. I did kinda screw up the sizing of my light bar and had to come up with a set of extensions but I got it worked out. The thing I like about these mounts is that, even though they clamp to the rain gutter, the weight of the light is put onto the roof of the cab, rather than the gutters themselves. The gutters just keep the mount from shifting around. Holds up well at highway speeds too. Now I just need to figure out how to wire the damn thing up so I can use it.
I just talked to Shane at Kahl Kreations and he's offering a free shipping promo. Use code FREESHIP and save $17 on shipping. He says he can also make your mounts without any design at all (just a solid piece of metal.
Code ends on Friday or into the weekend if he gets a lot of interest.
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
