41 - 55 of 55 Posts
The cruise and converter lockup goes off of the rear brake lights not the flasher. The led flasher just helps prevents hyper blink and allows the leds to work properly with the turn signals, i had to install a digital flasher and resistors in the rear brake light circuits. Running leds front and rear with no problems
Is it each light? I only have a halogen for my high mount and it seems to be doing okay?
there may be enough resistance with the third brake light using incandescent bulbs. I know if you run all leds in the rear you have to wire in resistors but only on the taillights and not the third brake light.
1991 Ford Bronco, w/95frontclip, 6"Superlift, Deaver J40 springs, 35x12.5 K&N, 3"Bassani
I like the double row of LEDs vs the single row I have. Looks great!
Discussion Starter #49
Got them in today, they look awesome. If they last as long as good as they look ill be happy
Heres brake lights only
heres running lights
Heres running light and brake
heres what they look like off
Looks like they've changed the design. You have a second row of brake bulbs where mine is part of the running lights
Theres only two listed in this style, black housing/clear lens and black housing/smoke lens which is what i have. The double rows of leds are brakes/turn only. The C strip and side led are running lights only
Actually am looking at seeing about getting a set of these for mine. Pity nobody seems to make a set for the front turn signals that are setup similarly to match.
i believe you can still find alpha headlights on ebay
I saw those when looking around, but mine is an OBS. If I my 90 wasn't wrecked (one day I may find a rough looking brick nose for a frame donor), I would consider those.
You can buy LED strips on Ebay and build your own to match. I built mine before I bought the taillights but they have similar features so go together good enough.
It was easy enough and there are a lot of videos online on how to remove the headlight lens and reinstall with butyl tape.
Very nice. Will probably see about adding that to my list of things to look into after I get mine back on the road.
41 - 55 of 55 Posts
