I have developed a grind in the left front of my truck in 4wd above speeds of 5 mph. Warn hubs were installed properly(i believe) and ive had the grind since i bought the warn hubs and replaced my left axle shafts. ive been thinking at this point it may be something in the front Diff causeing problems or even my Front D/S. Any help is appreciated.
Tim
did you install the hubs yourself or did someone else? because I had the same grinding sound in 4x4 with my 92 f150 and it turned out that the hub was put it wrong. I replaced the hub and its working fine now. Also does the truck actually engage in 4x4?
