hey all, just in the process of trying to level out my 95 bronco. It has 33's and I only wanted to go up enough to give clearence for them so i put in a set of procomp 2" lift coils, another leaf in the rear and ranchos all the way around. besides an alignment and radius arm bushings, and advice on what else i should watch for? thanks boys!!
Ex Navy Nuke
New higher angle camber bushings and either axle pivot drop down brackets or radius arm drop down brackets. Besides needing to fix your camber after adding the springs you'll probably need to fix the caster to take care of erratic steering.
