are there any front leveling springs that are light blue in color??may have found a set at the junkyard.has 2-3 more coils but the spring diameter is thinner than my stock set.don't know if it matters,but i've got a fairly heavy payload truck.very heavy rear springs and dual shock in front(with dual shock setup is there a heavier spring to go with??
Thinner diameter of the spring bar itself means it will be a softer rate. Adding a couple of coils will allow it to sit about the same height as a stock spring with a heavier rate.
If they are thinner diameter of coil, they may not fit in your buckets and mounts.
What do you mean by thinner diameter?
What do you mean by thinner diameter?[/QUOTE]
they are on a 87 ish 4x4.the cross section of the spring bar stock is thinner but there are more coils than what i have in my 86 now.with the thinner coils (and taller spring) is the ride going to be stockish or way softer than original.just by a quick look you can see the slight difference in diam.
Sounds like it's a softer spring rate, which means a softer ride. How much softer? Nobody can answer that without knowing the actual spring rates.
