1 - 9 of 9 Posts
Discussion Starter #1 (Edited by Moderator)
Looking for the “gutter mount” style light bar rack. I would be interested if anyone makes the brackets where I could fab up the rest of the bar myself. Also any links for quality new parts you may have saved I will gladly check out as well.
Addicted to Junk
I used a Carr brand Roto-bar back in the day. Very sturdy and well made. The stainless never ever rusted.
Dick Cepek used to make them, but not anymore
Yo BigNick98,
FYI, check out this Roof Cracks Repair Procedure TSB 96-20-11 for 80-96 @ Technical Service Bulletins
Excerpt;
ISSUE: Cracks may appear on the roof panel or on the corner panel sheet metal near the end of the drip rail at the B-pillar.
ACTION: Repair roof sheet metal cracks by using the Roof Repair Kit (F5TZ-9850223-A). Refer to Instruction Sheet #6661, included in the kit, for service details.NOTE: BE SURE TO REPAIR BOTH SIDES AT THE SAME TIME. IF ONLY ONE SIDE IS CRACKED, ALSO REPAIR THE SIDE THAT IS NOT CRACKED.The Roof Repair Kit (F5TZ-9850223-A) contains the following:..."
Repair kit by Ford now obsolete, see; Roof and B Pillar Cracks in an 82
@ repairs to roof
Source: by mickaila at FSB
Also, our for sale and want to buy rules require members to achieve 75 non-padded posts, due to scammers who have preyed on our members.
WANT TO BUY: FORUM RULES
If you can fab, the clamps simply sit on top of the gutter with an L bracket screwed or bolted over and under the gutter. Make what you want if you have the ability.
Addicted to Junk
Yep, most sit in the gutter channel, then an L shaped bracket is bolted to the side, and clamps under the gutter. I rocked one for like 8 years and never had an issue.
You can buy these types of mounts seperate, from companies who sell universal roof racks.
Thanks for the posts guys, I will for sure be checking out a way to fab up my own.
1 - 9 of 9 Posts
