1 - 2 of 2 Posts
What bolts did you use to attach the throttle body to the manifold. The bolts that run through the tb and egr spacer to connect to the manifold. Do the factory bronco bolts work? I found a thread on corral saying the size is 5/16-18 4.125" but I can't find anything in that size.
177753
When I purchased my upper it had the factory bolts installed. I purchased it with the factory Lightning TB. I don't remember changing the bolts this last time so I am going to say the factory bolts (studs) are still installed with Accufab TB I am now running.
hth
tim
Reactions: Burntoutaccountant
1 - 2 of 2 Posts
