1 - 2 of 2 Posts
I just got a 79 from the junkyard a couple weeks ago and i've got it running pretty good but there are some issues.
1. Power steering not workin......but the pump holds fluid and there doesn't appear to be any leaks....any ideas?
2. When we replaced the spark plugs on the left rear bank all the way back the plug we took out had oil caked on it......all over......it's obviously leaking somewhere there....but is oil in that area indicitive of something worse than just a head gasket or valve cover gasket....someone i know thought that might be the problem.
3. NO PARK gear somehow.......the damn gearshift won't go to it...i wouldn't worry about this if it weren't for the fact that the parking brake doesn't work either.
any help would be appreciated......;)
Teddy Bear
well the ps pump might be bad due to a siezed valve not allowing fluid to flow, on the trans it my just be the linkage that may be adjusted, really cant help with the other stuff just thought id give a little help
1 - 2 of 2 Posts
