1 - 20 of 28 Posts
Wrenching for a Livin'
some of you know I've been trying to sort out the parts and stuff i need to build this 393 stroker I've been planning for a while. Its beginning to come together little by little now. I've got the stroker crank and rods already, a few other parts too. Got the old motor out and tore down, cleaned up the parts im gonna reuse.
I finally decided to go with a set of Trick Flow Twisted Wedge Aluminum Heads, after a lot of research and help from some guys here, that help me out in THIS THREAD
heres the heads: http://trickflow.com/product/fordcylinderheads/twisted_wedge/pr_twisted.asp
I'm gonna order them as soon as i can get my tax return back.
And here's my latest desktop dyno file:
413 Horse @ 5 Grand, 529 ft/lbs @ 2500RPM's I wish i could figure out how to get the horsepower down a little into the lower RPMs without loosing torque, i guess i just need to look at some more cams. I know these numbers are not perfect, but they should be somewhere close :toothless
I'll be carburated at first. Edelbrock performer intake and Holley Street Avenger 670cfm carb. 10.5:1 CR (yes i know i will be running premium all the time) Long tube headers, Roller cam. Im gonna run my C6 till she blows, then swap in a ZF 5-speed.
I need would like to find a roller block somewhere too. Motor should be in and running before summertime. I'll Def. have it at Uwharrie for the R.I.T.S. By then i should have my 6 inch lift on too.
The parts pile is growing exponentially.....
Just thought i would share with everyone....More pics to come soon.
Id be happy with that over stock any day! Looks good!
The Anti Yam!
Holly Chit!!!!!!!!!!
I got Like 430 ft/lbs @ 3,000
That fawking rocks :beer :thumbup :toothless :beer
You got me beat Brother. :beer
But do remember both your numbers and mine are a little exaderated
DeskTop Dyno is rather generouse.
But ya still got me beat......WOW!!!!!!!!!
Yeah, i don't know how much i trust it really. Switching from carb to fuel injection doesn't really affect any numbers much, niether does puttin on a bigger/smaller carb. It doesn't take into account intake and exhuast runner size on the heads either. :scratchhe
But Im definitly happy :chili:
Lick my balls
magnumpi said:
413 Horse @ 5 Grand, 529 ft/lbs @ 2500RPM's .
When that motors broken in, I would love to see video of you roasting your tires off the line.
is FSB'd out
mmmmmmm, horsepower. Gonna have to be careful on the trail with that much power or u-joints will go bye-bye on a regular basis. Can't wait to see that sucker run, though. You got tires/gears in mind for that lift, too?
Ex Navy Nuke
Got me beat too. That thing is definitely gonna put a smile on your face. I guarantee you will enjoy it. After you get it broke in if you decide it's too much for ya I'll trade.:toothless
C6.....hummmmm I wouldnt mind that insted of my E4OD. Maybe I will take it off your hands one day and rebuild it.
And you will get it :thumbup
I guess I'll get to see how well maintained those 20 year old driveshafts and axles are. :) I got a deal on a used 6 inch front ttb lift, so i went ahead and grabbed it. Im gonna get a shackle flip for the rear, and i have some longer shackles to use as well. And i'm probably gonna get a set of Bent and twisted radius arm extensions too. I will def. regear and get bigger tires sometime, but i dunno if i will make it that far by RITS in july. Will eventually regear to 4.88's and I'm leaning towards 36" TSL's at this point....but i'm thinking about ground hawgs or iroks too. We'll see what time and money permits.
Whenever i swap it out, its yours. But theres no guarantee that it will be in good workin order...i dunno how its gonna like 390some cubic inches :rockon Although, it was rebuild about 70,000 miles ago
is FSB'd out
Let me know when you plan to throw the lift on there. I'm good at throwing sparks when necessary. And, where'd you get longer shackles? I'd like to do the same to level my lift out a bit.
Discussion Starter #11
Will do.....the shackles i picked up from a buddy of mine for 15 bucks. I have no clue what brand they are, or where they came from...they were in a box of parts he got when he bought a K5 blazer :scratchhe I know beltec....i think thats the name, makes some "lowering" shackles that some guys have used. Probably the easiest way to find some would be to look at lowering kits.
edit* found these at the bottom of the page in a quick google search: http://www.performancesuspension.com/TruckLowerTwo.htm
broncofied
I just found this thread apparentaly you were going more hot rod than i thought when i first gave you advice jeez. Your like me wanting a hot rod bronco:thumbup Oh by the way your gonna need a big radiator and a good water pump with 10.5-1 on the trail.
Discussion Starter #13
Yeah, i have really become addicted to power....
Im planing on a big 4-core and a highoutput water pump. And adding some water wetter to the colant mix. I have a tarus electric fan, but i think im gonna drop the money for a bigger aftermarket fan, just for safety.
I just may have to throw a T04 turbo in my plans to keep up with that. :shocked
Sounds great, keep us updated.:thumbup
Discussion Starter #15
Yeah...i just found out a minute ago that those numbers may not be right....my stupid self put a 351M/C cam into desktop dyno instead of a windsor cam....back to the drawing board....i might find another cam tonight
*edit-Hmmm.....turbo...i like the sound of that...i think i need 2 :toothless
broncofied
Actually smaller tubes in big numbers cool less effectively than two larger tubes. The goal is more surface area to transfer heat try to find large tube two or three row.:thumbup
Discussion Starter #17
i don't think i quite follow what your saying...do you maybe have some pics or something? Im a little slow tonight...
Yeah, who needs a hydraulic flat tappet cam anyway......solid roller's what it's all about. :brownbag :D :D
Discussion Starter #19
i dunno about solid....but im def. going hydraulic roller :thumbup
Harmful if swallowed
My dyno is showing pretty solid 300/400 with just 357 cubes for my motor at 9.0 compression, so your numbers sound decent for your setup. Mine was about the same when I was playing with the displacement and compression too.
I've got a set of Roush 200 cylinder heads sitting in the garage waiting. 2.02 intake and 1.6 exhaust, 200cc runners. Also planning 4.10 gears with 32's for mine, should be fun:thumbup
1 - 20 of 28 Posts
