What you do (if your header gasket is like every other header gasket I have ever seen) is take out the middle bolts and loosen the two outside bolts. The location for the outside bolts on the gasket isn't holes, it's a slot, so you can slide the gasket into place and those two bolts hold it in place so you can get the other bolts on.
