1988 Eddie Bauer - 5.8. C6, 33's but no significant engine mods.
Hello Bronco Fam -
Overview:
I am looking for logical upgrades to a 1988 Bronco Eddie Bauer, 351W, C6 transmission.
I have done a lot of work to the rig recently and it is now running extremely well. Now that I have sorted the majority of the mechanical errors I was facing I am reaching out to the community to help me determine what is the most logical upgrade path to take for future improvements.
I am mostly interested in reliability, preventative maintenance, quality of life improvements, performance, then off road capability. I don't live in an area with a lot of access to off road trails, that's the only reason it is lower on my list.
Requirements:
These need to be projects that 1 reasonably skilled person can accomplish with basic tools. I don't mind getting new equipment if I have to, but the upgrades will be performed in parking lot. I don't have welding equipment or air tools. I do have a friend with a shop who will let me use his lift and borrow some tools, but I can't leave the truck there overnight. I need to plan on 1-2 day projects. I would also like to keep the budget in the $1K or less range per project. I'm trying to do these upgrades in little digestible chunks.
Things that have already been done:
Overview:
Requirements:
- Engine has been rebuilt
- Transmission has been rebuilt
- Transfer case has been rebuilt
- New brakes
- New tires (33 inches)
- Ignition has been mostly replaced
- Air intake has been upgraded
- Headers installed
- Truck has been painted
- Body work has been done
- All door locks and windows (including rear winder) are functional
- Plugs and wires are upgraded
- AC has been repaired/restored
- Vacuum lines have been replaced with silicone lines
- It already has a small lift (I think its 2 inches)
- IAC, TPS, and many of the gremlins that raise their heads with age have been addressed
- Install ported and polished upper and lower intake and throttle body
- Replace injectors with Ford Explorer "4 hole" injectors
- Install new valve covers and gaskets
- Convert from MAP to MAF electronics
- Convert to electric fan
- Repair/Upgrade wiring
- Inspect and replaced bushings and mounts
- Install carpet (currently bare floors that have been coated with bedliner)
- Install stereo
- Repair exhaust leak (not sure where it is, but I can hear it)
- Swap NSS - it currently has a 4 pin one, I need a 6 pin one, will have to be installed before April to pass Virginia safety inspection
- What am I missing?
- Are these logical improvements, if not, what would be?
- What have you done to your vehicle that made a significant improvement that should be added to the list?
- What parts are prone to failure that I have not included that should be?
