1 - 2 of 2 Posts
I have a 86 bronco 351w and what I assume is a C6 transmission. I began installing the Holley Sniper EFI when I realized I needed a new throttle bracket and cables to make it work. So I bought the Lokar kickdown cable, throttle cable, and bracket. I removed the kickdown rod already but when trying to mount the kickdown cable bracket to the transmission, the screw I thought I needed to connect to slipped inside its housing. I then removed two bolts to remove the piece but I am not sure if it is supposed to be removed up or out in order to see whats up with the screw.
174226
^^ Kickdown bracket wont fit on screw because of this other contraption in the way.
174227
^^Didn't fit
174228
^^Screw Slipped into housing
174229
^^Don't know which way to remove this
that contraption is your neutral safety switch. I have not done my lokar kit yet, but I'll be under my truck saturday having to get ready for it. I'll take a look. mine is an 86 351W w/ C6 as well.
1 - 2 of 2 Posts
