1 - 8 of 8 Posts
My 94 bronco maf with a 302 has a long crank when warm. If it's cold and I go to crank it, it starts right up. If it's hot and I shut it off and crank it right back up again it starts fine. But if it's hot and I wait for an hour and try to crank, it takes a solid 5 seconds to start. Once it starts it runs fine. If I hold the gas and crank it starts fine but I see black smoke out the exhaust. The timing is at 10 deg btdc and it has a new ect sensor. Fuel pressure is good when cold and hot, cranking, and running. I undid the vacuum line and the pressure rose so the regulator is good. I put my scan tool on it and the ect readings were accurate and the iat temperature was accurate also. Once I shut it off the fuel pressure holds good whether it's cold or hot. Don't know what it is. Truck runs good otherwise and there are no codes.
mine was doing that...
was told an injector was leaking down.
i replaced all my injectors with the newer EV6 style and haven't had a problem since.
But if my injector was leaking wouldn't I see fuel pressure drop? Also, no matter how many times I prime it, it still takes long to crank when warm
Leaking fuel injector will flood the engine
It should.
But your also saying with the accelerator pressed it will blow black smoke. black smoke is overly rich.
Pulled the upper intake, ziptied injectors to fuel rail so they wouldnt pop out, grounded fuel pump, turned the ignition on and no injectors were leaking. I stuck paper towels under each injector and there was no wetness. Hooked pressure guage up and it dropped 16 psi within 5 minutes after turning ignition off. Dont know what else it could be. Any ideas?
1 - 8 of 8 Posts
