1 - 3 of 3 Posts
Ok ok, I know not a Ford, I'm trying to find a diagram of a valve body for an GM 700r4 trans. I want to find out where all the check balls go, and what exactly every part inside is.
The trans is rebuilt, new torque converter, 500 miles on the trans, and it doesn't move forward, and barley moves in reverse. Ive had the trans apart, all the clutches are good, all the seals, everything. I put a new torque converter in it when I built the car, and i even changed that out with one I had laying around to see what it would do. So now I'm getting into the valve body, there are a few things i dont really like in there now.
Need more info on the trans;ie 2wd,4wd.Would also be helpful if you could tell me the original vehicle for the trans as there were some changes throughout the years.When you say it barely moves in reverse does it just race up like its slipping or does it feel like it is being powerbraked?Same with drive?
Satyr of the Midwest
Not the first time a guy with a GM wondered where his balls went.
:histerica
Kidding, kidding.
1 - 3 of 3 Posts
