Over last weekend, I had to replace the starter, Fan clutch, and battery... OK all good and if was fairly simple. I hop into the ride today and head on down the highway, 15 minutes into it and the check engine light comes on. I get off at the next exit, and as soon as I do , the light goes off. I didn't do anything different and it drives just fine. What I am wondering is if anyone has any ideas of things I should check now? Does the light leave a code in the system so I can go back and see what the error was?
I checked the oil and it was about a half a quart low (will put it in at lunch). I tried checking the Transmission fluid while it was still hot and running form the drive to work, and it seemed OK, but I didn't see a clear defined line on the dipstick from the fluid (more bubbles and etc). Any suggestions on how to get a more accurate reading on this part?
Thank you guys for all the great help you have given me!
