OK, other night was pulling a Tahoe out fo a ditch. Both hubs locked, 4 hi, went to pull and first hard pull after tightening the strap a loud pop came from the front right tire. Tried to unlock the hub but it wouldnt unlock. Had to unlock it with chanelocks. Other side unlocked fine.
Jacled the truck up to check and see what was wrong. When I lock the left hub and spin the wheel the driveshaft turns. This does not happen with the right side, although the hub does lock and unlock regularly now. I know the hub is ok, and the u-joint closest to the wheel is also OK.
So what is left? Is it the axleshaft? The pull really wasnt very hard at all. I didnt think it was enough to break an axle. Or could it be another u-joint in the axle?
BTW, truck will still pull in 4x4...lock just the front left hub and in 4x4 the front left tire will spin.
