Update... loud tap after cam swap, 427w stroker
Flat tappet cam went flat so I swapped it for a Comp cams retro roller kit. I didnt use the Comp lifters: Standard Ford spider style... Instead I used Lunati link bar roller lifters.
Now I have a very loud tap that matches engine rpm.
It seems to come from the pass side of the engine. I checked lifter/block clearence, double checked rockers...
I am hopeing the bad cam didnt cause some other damage!
You all have any suggestions shourt of tearing the engine down and going through the whole thing?
Thanks.
https://www.dropbox.com/gallery/42617308/1/Truck pics?h=03f467
No sign of valve to piston contact...
Video of valvetrain:
http://dl.dropbox.com/u/42617308/video of truck motor sept 26 2011.MTS
Thanks.
