Just put in a new shift motor. 2>4 works great, but nothing when I try to switch into low. Its the switch, motion sensor, or what? I'm trying to isolate the glitch. I can't find a schematic for the circuit, can I bypass the motion sensor (green-blue-brown) wires from the shift motor? I can at least verify that it works or not.
yo Luke,O
K!
1356 Electric Shift Speed Sensor Location & pic in a 92
Source: by yoomooman (eddy) at http://www.supermotors.net/registry/19348/67103
1356 Electric Shift Speed Sensor Replacement Information; "...took about 45 minutes to remove the yoke, tail housing, and solder/splice/heat shrink the new sensor in place..."
Source: by kf4amu (Will H, The Beast) at http://fullsizebronco.com/forum/showthread.php?t=174202
1356 Electric Shift Speed Sensor Wiring Diagram & "...The speed sensor is important because the vehicle must be stopped for a shift into or out of 4L. The shift module won't make the shift if the vehicle is moving. speed sensor should show 225-275 ohms with the vehicle stopped. Check at the module connection..." Miesk5 Note Ford Part Number is 7f293 speed sensor
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at http://ylobronc.users.superford.org/documents/electric1356/elec1356.htm
Thanks Miesk, I discovered no voltage coming from the MLPS in pin #1. Guess it's clearly the Safety switch. Speed sensor read ~290 ohms. I'll put on the MLPS tonight.
Thanks again.
GREAT SUCCESS!! Back up lights act normal, xfer case works perfectly now. Thanks again FSB! Damn this place makes my life easier. :) :)
