I have a np 435 that I just rebuilt completely. In the past I always put a quart of lucas in then 80 90 to fill it up. Should I do this again or just use 80 90
I can't say I have a ton of experience with np435's, but I've only put 80w90 in mine since I've owned it (about 3 years). Seems to work for me, but you'll probably get differing opinions when it comes to oils.
If it makes you feel better, some Lucas definitely won’t hurt. But I think if everything is rebuilt, just plain old 80 90 will serve you good for a decade or two....
I've been using a mix of Lucas and gear oil my diffs and transfer case for years now with no issues, they seem to run cooler and quieter.
Reactions: miesk5
I've used lucas once in my life, for a transmission with a lazy valve. I wouldn't put it in anything that's working properly. Some good quality gear lube is all your transmission needs.
