1 - 2 of 2 Posts
i have a 95 f150 with the m5od trans hat just went out.
i also have an 86 bronco with np4355\208.
wht wil i need to swap the m5od to np435
Local # 40 Boilermakers
should be able to swap it in if you use everything from the trans you are using. Might need to have you drive shafts modified or find some in a jy that will work.
1 - 2 of 2 Posts
