Check out our Drill Bits. These are proudly Made In USA.
We have tested out a lot of drill bit manufacturers and found a mix that works well. These bits get consistent results and deliver a low cost per cut.
We are crunching numbers to get some discount codes worked up on the drill bit sections.
Made In USA Drill Bit Index's
Carbide Burs Made In USA
Single Drill Bits Made In USA
The other thing we just added is a 29 Piece Index that is a great value.
The bits in this 29 Piece Index are Made In the USA, Black Oxide and graduate from 1/16" to 1/2" by increments of 1/64". We have experimented with imported twist drills and the quality just isn't there.
USA is stamped right on the shank! USE Discount Code: GRIT
Black Oxide Drill Bit Set
