Ok, my laptop, which has everything I need for work....... I mean EVERYTHING is F'ed up some how. I am running windows XP Home edition, the computer was purchased new, but did not come with any disks, everything was supposed to be self contained.Worked fine at work today, but when I got home and tried to turn it on I got this message on a black screen with large white letters:
We apologize for the inconvience, WIndows did not start successfully. A recent Hardware or software change might have cuased this.
If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose the last known good configuration to revert to the most recent settings that worked.
If a prevoius startup attempt was interrupted due to a power failure or becuase the power or reset button was pressed, or if you aren't sure what cuased the problem, choose start windows normally
(It then gives me these options on the same screen)
Safe Mode
Safe Mode with networking
Safe Mode with Command prompt
Last known good configuration
Start windows normally
Use the up and down arrow keys to move the higlight to your choice:
Seconds until Windows starts: (and there is a 30 second countdown here)
I have tried highlighting every single one, and nothing works, it acts like windows is loading and I get a blue screen with some white writing for less then a second, so fast I can't read it, and I tried to puase it, but that didnt work. IF I don't shut it off it will do this continuosly. What do I do???
:banghead :banghead :banghead :banghead
Safe Mode
