Has any one put a manual choke on the 300 1bbl? if so where did you put the bracket that holds the cable? I cant seem to find a straight enough shot and it's binding up.
I ran my cable through the hold in the firewall where the ECU harness was. which is basically at the bottom of the dash and to the left of the ash tray. I had trouble using the brackets so i zip tied the cable as tight as i could to the accel cable. The choke should be setup as full choke when pulled and open when pushed .
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
