i just put in manual hubs on 96 5 litre bronco dana 60 axle the only way they would fit is by leaving out the thrust washers and c ring .warn premium hubs . warn instructions say to use them. but no way would they go all the way in they seem to work fine. any thoughts ?
Designated Tranny Killer
did you read the write up on here about it? you have to pry the shaft out a little bit to get the clip on
If you've got a friend helping you, have them "pull" the axle outward, and you can put the snap ring on, or if you're solo, use a big flat tip screwdriver to put pressure on the axle and then hold in place with your foot while you get it on. I have done it both ways!! Good luck.:thumbup
