1 - 9 of 9 Posts
· Engineer
Did Ford change the pedal assemblies between 88 and 94? I'm working on my ZF swap and the brake/clutch pedal assembly from my 88 parts truck doesnt look like it's going to fit in my 94 Bronco. It's hot outside and I'm tired but I swear it wont fit. Does anybody know they're it's not supposed to fit?
· Engineer
Steve83 said:
Yeah, dramastically! You need a manual pedal assembly for '92-97.
You got one??
· Engineer
I'm going to be looking for 92-96 pedals first
When i put my 5 speed in to replace my auto in my 1990 F150 everything i had was out of a 1995. on the 95 there clutch pedal with mount was attached to the rest with rivets. I cut the rivets and bolted the clutch pedel mount to my stock pedal system after drilling some holes. If i'm right the 95 accembly wouldn't bolt up under my dash.
· Engineer
Discussion Starter · #9 ·
The 88 assembly is all cast together
1 - 9 of 9 Posts
