Hey Fellas,
After having two E4ODs take a dump in my 93 Bronco in less than 2 years, I figured it's time to ditch the E4OD and swap something else in that's stronger and more reliable. I did a search and found the following informative threads:
E4OD to C6 swap:
http://fullsizebronco.com/forum/showthread.php?t=55723&highlight=e4od
http://fullsizebronco.com/forum/showthread.php?t=9824&highlight=e4od
http://fullsizebronco.com/forum/showthread.php?t=45474&highlight=e4od
Auto trans to manual trans swap:
(AOD to NP434):
http://fullsizebronco.com/forum/showthread.php?t=54491&highlight=e4od
(E4OD to ZF):
http://fullsizebronco.com/forum/showthread.php?t=49198&highlight=e4od
I found other tranny swap threads that were equally as informative. However, my question is which would be better/stronger? An NP435/ZF/T-18 or a C6? I realize the C6 does not have overdrive and that mileage will suffer on the highway when compared with the E4OD. But I don't drive that fast on the highway, and I have another vehicle with much better mileage than the 302/E4OD combo.
The manual tranny swap seems more compicated as far as scrounging for all the parts when compared to the C6 swap. However, if the NP435/T-18/ZF manuals are stronger and have less of a chance of requiring replacement/rebuilding than the C6, then I'll go that route, because frankly, I'm getting tired of having to drop heavy trannies in my driveway. Conversely, if the C6 is stronger and more "bulletproof" than either of the manual transmissions I mentioned, then I'd rather go that route.
One last thing to consider is availability and cost of the transmissions. I think the C6 is probably easier to score for less money than a ZF. I also think the T-18 is probably rarer. So my guess is that it might be easier to get a C6, but I've already called a few local salvage yards, and none have a smallblock 4x4 C6 in stock, so go figure.
My 93 Bronco sees occasional daily driving/commuting/dog transporting and occasional weekend wheeling maybe once a month. I don't plan on racing it or thrashing it off-road. It'll most likely see a few long distance highway trips a year, but most weekend trips will be 4 hours or less.
FWIW, it's a 93 Bronco with a 302. Thanks for any info.
E4OD to C6 swap:
(AOD to NP434):
(E4OD to ZF):
