My manual windows have never been very smooth. A couple days ago the driver's side was binding up pretty bad, had to play with the window to get it up. I pulled the panel off, and found if I lifted up on the arm it operated smoothly. I pulled the regulator out today and it operated fine, but the roller was sticky so I thought that might be the problem. I cleaned everything up, lubed it with white grease and reinstalled it. It was a little better, but would still bind up, so I guess the gear must be worn, causing the binding.
@RockAuto lists a few manual regulators: WAI GLOBA, ACI, CARDONE, and MOTORCRAFT (high $$). LMC and A1 AUTO have them, but don't know the brand.
Does anyone have any recommendations for a replacement? I would really like to avoid Chinese junk if possible.
TIA
TIA
