Yo Rex,
Welcome!
What year and trim model (such as 96 XL or ELT, etc do you have?
In an 88 member Jem270 stated, "According to my wiring diagram, the power to the green/yellow stripe wire is always on." So test for voltage before trying the following,
For now, pull rocker door scuff plates and see if you can pull up some slack in #14334 wire harness. Or pull 1/4 panel trim panels.
Other owners such as Jem270 have cut out the bad section & connected all the wires of each color together using crimp in-line conbectors and some new "primary wire" from the parts store. Also, after stripping insulation inspect wire stands for corrosion,
Welcome!
Item | Part Number | Description |
1 | — | To Interior Lamp Assembly (Part of 14334) |
2 | 14334 | Wiring Assembly, Interior Lamp Feed |
3 | — | To Radio Speaker |
4 | 14335 | Wiring Assembly, Interior Lamp |
5 | — | Stow Connector in Hole Provided |
6 | — | To Map Light |
7 | 14A504 | Wiring Assembly |
8 | — | To High Mount Stoplamp |
9 | — | Remove Release Paper Before Application |
10 | 5420552 | Insulator, Body Opening Sound |
11 | 6054350 | Insulator, Roof Side Inner Rear Rail Sound |
