So before I spend money on the “fun” stuff like gears and what not, I need to address some issues that keep popping up. First was the rear window which was a faulty safety switch. By bypassing that, it seems to be take care of.
I picked my son up from school yesterday and when we got home, the drivers side window wouldn’t roll up. Again. This happens often and I need to buy a replacement motor and be done with it. The doorman model I bought from autozone worked great but the bolt pattern wouldn’t line up so I need a fomoco one. The weird thing is that it works off and on. It’s like the motor is sticking or something. It’s not a wiring thing. Just something in the motor.
The long crank after the first start up. I have no clue how to figure out what the problem is here. I need to find the starter and see if the heat shield is there or if It needs one. Is there a way to test the starter?? Should I just replace with a high torque model?? I would love to know tour thoughts on this. I assume it could be a fuel issue, starter, ignition system, etc. I am just really lost on all of this. Probably would not hurt to do a fuel pressure test also just to check things out.
Lastly (for now) is steering. I would like to replace my steering gearbox with a red head or blue top model and install a Bergeson shaft. I truly believe this will take care of 90% of my steering issues. This will probably happen after the top two issues are fixed. As of now I can drive it the way it is but if it leaves me stranded or the window won’t roll up when it’s raining, I have bigger issues. Any advice or ideas on this stuff would be greatly appreciated.
