1 - 20 of 47 Posts
Haven't been on fsb in awhile and was hoping to make it this year. usually dm2 has a thread started by now with periodic countdown posts
Good luck getting the bronco back together
End of april, full size invasion of the bronco safari. Check the mountain state group, its gotten pretty big.
That looks great, Rausch will be a little bit of let down after that trip
This will be the first I’ve missed since ‘10 I think, bit far for me now.
Is that you Colin?
Everything is going great. How's the move to Denver working out and when did you move?
Hopefully I'll see you there
Good to hear. It’s been wonderful, I’m really enjoying being here and thankful it went so well. We left VA the end of June, about a week after last years Roundup.
Erik
So I was scrambling to get my big bronco done and would have until I found more issues. Turns out my pinion in the Dana 60 partially broke some of the teeth off. After having someone more experienced look at it they also think I bent the short side axle tube. It’s currently at a shop waiting for them to confirm if the axle is bent and seeing if they can do anything about it. On top of that it still leaks trans fluid.
But on an unrelated note in about a week I will most likely be purchasing another bronco. This one is cheap despite still running and not being completely rotted out. I intend for this one to stay stock and just drive. But instead of my normal Wed-Sun at the cabin I changed my rental to Fri-Sun. Unfortunately I won’t be wheeling unless I decide to take this untested bronco on some easy trails. Instead I’ll probably just hang around and do other stuff with this bronco.
Sweet, i promise not to spot you into certain danger <img src="http://www.fullsizebronco.com/forum/images/smilies/toothless.gif" border="0" alt="" title="" class="inlineimg" />
Thanks. 😁 you might have to take a few pictures for me though.
1 - 20 of 47 Posts
