I've wanted to do this for years. Actually grabbed a D44 from a forum member in Maine back in 2009. He wanted it gone, well, his mother wanted it out of her driveway. :whiteflag
I gave him $40 for his time to drive it the MA border and met him there. It has sat in MY driveway for the past two years, and recently MY WIFE has made it clear that she is tired of seeing it. :histerica
Seems to be from a '78. The BOM is 610019, but the BOM numbers online do not start until 610023. So this axle is either a late 77 F150 or early 78 F150/Bronco I figure. The other key code is D8TA. The stock radius arms had been torched off, but the C's were both there. The spring cups are rusted and one is bent pretty badly.
The subject for this swap is my '96 Bronco. Bought her 11 years ago.
Yeah, it's not a very recent pic, but it looks the same right now as this spring, and it was the closest pic I had on hand.
The rear has already been done with Deaver's 5.5" lift springs. If necessary, I can ad a 1" zero-rate to level the truck out. I need to get the truck in to have the Eaton Posi checked out. The guys that did the initial work 100,000+ miles ago are down in PA. I went in to see them recently and either the clutches are bad and need to be replaced, or there is a problem with the housing. They want to dismantle it prior to making a call on the real cause of the noises. Hoping to get that done sooner rather than later.
Hopes - about a 6" lift. I have 33's now, but 35's would be great. 37's might be too much, but I've never seen a Bronco on 37's in real life, so I'm going to get this work done, and see what space I have to work with and go from there.
My reading shows that with '78 coil buckets, a 6" '78 spring nets you 8-9 inches, so I guess a 4" coil with the stock buckets is what I want. I want the front and rear to behave the same, so Deaver coils will be used up front. I do plan to move the buckets forward an inch as everyone does.
As for the radius arms - James Duff. I know they are costly, and will be the biggest ticket item in this entire build, but I'm not a "structural" welder, and I know it.
When it comes to the track bar mount, I'm going to go with FoxBravo's suggestion of the SuperDuty drop mount. I'll start with the stock track bar (and new bushings) and go to the bullet proof unit once I have a measurement.
Steering - my plan was to use the stock tie rod setup and use the adapter to run the late Bronco pitman. I'm not a hardcore wheeler, so don't need bulletproof steering at this point. I was going to go the "stock" route to save some money. Looking at the prices of all of the parts and that crap adds up quick.
New trans mount is required by the Duff arms, so I'll get on that so it is ready when the actual swap occurs.
The gears and limited slip will come out of the TTB and be installed in the Dana 44.
Started to tear it apart last night and get it cleaned up. Doing this alone, I was glad I put a 3-point hitch on the tractor:
After a few hours of wire wheel and conditioning pads, and she is looking better than ever. Still a few more hours to go to finish the ends and clean up the center section.
The track bar bolt came out easily with the hot-wrench and PB Blaster. :goodfinge I have no idea how I worked on stuff before buying that!! So that is just a new grade-8 bolt to replace the original one?
So, how the hell do you clean out the tubes???
And with the gap between the tube and the axle shaft, anyone ever try a tube seal like these for the Jeep guys? http://www.4wheelparts.com/Drivetra...s.aspx?t_c=12&t_s=237&t_pt=101188&t_pl=103311
Lastly (for now anyway), the C's seem to have quite a bit of rut, but I cannot tell if they are still good or if I should find other units.
Cannot wait to get progress on this project. Thanks to everyone who has done this before and paved the way for everyone else! :thumbup
