1 - 20 of 23 Posts
I always love to hear whos done what to their bronco..... heres my list:
Was: 1989 bronco XLT 5.0L AOD... stock on 31s 250 000kms, bought sept 2004...
Now: 351W .040 over with FRPP *M50 cam and roller rockers, edelbrock alluminum heads, BBK twin 56mm TB and BBK headers, FRPP 24lb/h injectors, 302 upper intake manifold and port matched stock 351W lower manifold, FRPP MAF converson with C&L 73mm MAF housing and 24lb/h sample tube, 3" custom exhaust with magnaflow muffler, 3G alternator swap, saginaw PS pump swap, ZF 5 speed transmission swap, BDS 6" stage II lift, dual BDS steering stableizers, 4.56 gears, front aussie locker, rear beefed eaton posi, 36" TSLs, warn premium hubs, winch bumper, 9000LB warn winch, 2 KC daylighters, 2 PIAA 520s.... Im sure theres more too.....
next year... SAS
:shocked
Got some money on your hands?
one thing you'll notice about us bko owners, we like to see pics.
that heat wrap works just as good as the aftermarket parts for 2-300 bucks.
gibson shorty headers
3 inch gibson exhaust, connected to a magnaflow high flow cat.
voltage, water temp, oil pressure
everybody needs an optima in their life.
4 inch rancho lift kit.
4.10 auburn gears, figured chrome cover why the hell not.
water in the motor is never a good thing, but i looked at it as an oppertunity to build the motor, bored .030 new valve springs, crane 444232 cam, i'm contemplating the edelbrock truck manifold, which will probably be there shortly. i'll get some pics of that when it gets put together.
Here is an idea......Go to Superford, search on FSB members and browse everyones pages.
That should keep you busy for a year. See ya in 06.:drinkbud
Call Me Ace
just because im bored at school- ill post my "extensive" list of mods:
replacing stock items:
3 starters
2 alts
3 batteries
1 ignition switch
all window motors
starter relay
starter module
in line fuel pump
in tank fuel pump
mods:
radio shack classic 40 channel CB radio
twin 4' fiberglass trucker antennas
31" BFG land terrains (theyre cheap- and the truck sees 350 miles of road a week... not too much off-roading)
pioneer 2-way speakers in front
pioneer 3-way speakers in back
JVC cd unit
custom sawz all rack
im working on a couple more- but i posted a thread about those a while back.
ace
go to my link below
Eddie Bauer Edition - stock 302
* Replaced engine with EFI 302 from '91 F-150
* New HD Starter
* New Starter Relay
* New HD 130amp Alternator
* New HD Battery
* New Ball Joints
* New U-Joints
* New Axle Seals Front and Rear
* New Warn Premium Hubs
* Fenders Trimmed and Bushwacker Cut Out Flares installed
* Chipped, Hammered and Ground down all rust under entire truck - axles, floor pans, frame, wheelwells, etc
* Undercoated Completely with POR-15 Rust preventitive Paint
* 35x12.50 Dunlop Mud Rovers
* Black 15x10 Rock Krawler Rims
* Sanded and painted the top with Krylon
* Brand New Gas Tank and Sending Unit
* New Master Cylinder and Brake Booster from F250
* 700 WATT Power Inverter Mounted in Glove Box
* RAM Tow Hooks in Front
* Grill Guard with Dual 100 Watt Lights
* New Heater Core
* 6" BDS Suspension Lift with Extended Radius Arms
* Braided Brake Lines Front/Rear
* Extended Differential Breather Lines
* Full 10 Point Roll Cage
* Homemade Half Doors
* New Fuel Pump
* New Feul Pump Relay
* Home made 3" Snorkel
* Home made Rock Sliders
* CB and 4' Firestik Anteanna
* Warn XP9500 Winch
* 200 AMP 3G Alternator
* Dual Batteries
* Inverted Class III Tow Point/Hitch
* Mini-Spooled 8.8
* Cut Rear Bed and Raised Gas Tank for clearance
Igintion Switch
Fuel Pump Relay
Starter Relay
160 Amp 3G Alternator
Red Top Optima Battery
U-Joints
Ball Joints
All New Steering Components
Sun Visor
Air Deflector
Steps
Grab Handles
Electric Radiator Pusher Fan
Seven 100 Watt Fog Lights + Light Bar More to come :)
Water Pump + Hoses + Thermostat
1 Gauge Battery Wires and Ground Wires
K&N Drop in filter
6" Rough Country Lift
Rear 4.5" Leaft Springs
Drive Shaft Extended + Balanced
Extended Brake Lines
8X15 Black Steel Rims
Master Craft 35x12.50 15 Tires
Camo Spray Paint Job
Camo Seat Covers
New Tailgate
Rebuilt Rear Window Motor
Rain Guards
MP3 Cd Player
Infinity Kappa Front + Rear Speakers
12" Kicker Subs
2 Fire Extinguishers
Custom Exhaust "None haha"
Current
Edelbrock Performer Intake
Edelbrock 650cfm Performer Carb
Edelbrock Air Cleaner
K&N 3" Filter
Flex-a-lite Fan
"Bronco Powered By Ford" Aluminum Valve Covers
Crate Engine 351w
Crate C6 Tranny
Flowtech Headers
Dual Exhaust w/Flowmasters
160amp Alternator
Procomp HEI Distributor
Rebuilt Tcase 208
Door Panel Upgrade 85 to 88
Ford 9mm Wires
Hitch
3 Core Aluminum Radiator
Manual Lock Hubs
High Volume Oil Pump
Todo
4" Lift Kit
Electric Fans
33" or 35" Tires
Diamond Plate everything
Custom Console
New Paint
Roof Lights
Custom front & rear bumpers
Lockers & gears
C6 shiftkit
I killed Kenny...again
you're openin' a can of works with this thread
*6" TTB lift (since removed)
*35" thornbirds (worn out and replaced)
*motor rebuild
*trans rebuild x2
*4.56 gears
*35" TSL's
*Eaton limited slip rear diff
*AGR steering box (waste of $)
*bushwacker cutout flares
*fastback soft top
*10 ft CB antennae
*Duralast 80a alternator
*F-250 rear leaf springs
*D44 SAS, 9" lift coils
*snorkel
*spooled VSS compatible Dana 60 rear
*custom ******* tube doors
these are all in chronological order too
new trans, tcase rebuild, and tires are on their way. and a 10pt cage from S&W
my next mod is to install a Slurpee machine in the center console.
Wrenching for a Livin'
:stupid
List of mods ehh?
Cb
Warn Standard Hubs
Dont have a pic for them yet... :duh
Missing Pass Step
Missing exhaust pipe (Same pic just notice behind the wheel no exhaust pipe, i knocked it off the truck my last trail run)
And Custom Spring Bracket Suppot :toothless
Started out stock 1 year ago with a I6 300ci motor
$-429 motor installed w/ [email protected] brackets
$-Headman headers
$-Holley Carb
$-4 inch Rancho Lift kit w/extended Radius arms.
$-3 inch body lift (rubber bushings removed)
$-Bushwacker cut out flairs
$-38.5x14.5x16.5 Super swamper sx's
$-2 inch wheel spacers (in Front)
$-Rear shackel flip with stock brackets and 2inch longer shackel.
$-Rancho 5000 shocks
$-MSD 6al Ignition
$-Ramsey winch out of a tow truck dc200
$-Custom bumper in the works needs to be welded
$-9" rear spooled
$-Dual battery w/isolator
$-Cobra Cb
$-After market front grill
$-Gutted the interior and ready for Herculiner
Thats all that I can think of right now tons more to come.
o[|||]o
plug ugly said:
i swapped out my automatic hubs and put a CB in there
There was more, but it was trivial by comparison. :toothless
FSB warrior
thats all ya need:thumbup
1 - 20 of 23 Posts
