61 - 80 of 372 Posts
Discussion Starter #63
Getting Better
The state of my lower back was improved enough today that I decided to go to the garage! Check it out!
Got the rear most floor patch welded into place tonight then ground the high spots off so it would not hurt the knees when kneeling in the rear of Patches. Yes I do believe I am going to adopt the name Patches for the Bronco, the tally is up to 31 total "Patches" to date. I think it looks good if I must say so myself! Gonna have to spread the top of the rear quarters again, welding in the rear panel brought them in about 3/4 on an inch. Nothing to worry about thou, I fit the weather string in for the tailgate and am very happy with how it is going to fit! I will be off tomorrow night and back at it again on Wednesday! I also got the steel for the snow plow mount today as well as a 4' X 8' sheet 0f 16 gauge sheet metal for the rear panel, overhead shelf and consol, and the center consol. Moving along....... O yea another roll of wire has been melted into Patches! Thats 1 small roll and 1 11 pound roll of .030 wire!
'95 XLT: 5.8/MAF/E4OD/6" lift/4.56's/33x12.5x15
^^^ are you mental or just not so good at forum communication? :goodfinge
Damn man. Looking better than I expected in 1/10th of the time. :popc1: :beer
you make me ashamed to not have ripped into the few, small rust holes I've got waiting for some love.
Glad you like the "handle". Seems to fit. :thumbup
Mate thats a butt load of patches but its coming up really cool. So whats the end plan? 4wding and snow plough? Be keen to see how it all comes out. Your patch work is coming along great!
Discussion Starter #67
Thanks
Patches progress is coming along well! I have enough failed projects under my belt to know that I need to stay focused and determined if I plan to finish this one!
Kiwi, Patches will be used to plow snow mainly, but there are underlying reasons for building him as well. You may have noted the graphic I plan to use is BOV1. Bug Out Vehicle 1. Now don't you guys go crazy about me being a prepper. I feel someone should be ready for the things that are likely to happen in there area so I am building a rig that could if need be get me home or away from home in just about any type of weather situation, not to mention a rig that I can take wheeling again and not feel guilty about scratching or covering in 2" of mud. It didn't feel right doing that to my big truck.....
Cruising thru other threads on any forum one gets excited to see pictures that support the text. In my thread I am trying to make my readers excited about the text that supports the pictures! I love pictures in posts, it lets the reader feel as thou there are there with me!
Discussion Starter #69
No pictures to add today.... but I did get 4 more patches welded into Patches last night! All the holes in the rear of the tub have been filled and fully welded from the top! Tonight I have a couple of areas in the middle of the floor to take care of and I hope to start on the passengers from seat mount!
Mate I get the BOV thing. Here in NZ we get a fair few earthquakes. I'm close to Wellington and its overdue for a biggy. I've got an old 89 Nissan 4WD called Rosie that I've always thought if the poo hits the whirly thing, I'll be using rosie to get me round. Shes a good old truck thats never let me down.
Discussion Starter #73
Welding
Thanks! The funny part about Patches is I am positive that he rotted from the inside out, even last night I was looking at the underside and did not see any of the tell tail signs of rot. Everything underneath still has a decent amount of undercoating on it. You guys will see when I get the tub off! Has anyone else noticed that there Bronco's are rotten from the inside out?
Buddy mine kinda did but ultimately its cos water was leaking in somewhere higher. Where the leak was was a small patch. Where it ended up tracking to and sitting within wet carpet....quite a bit bigger patch :toothless.
If you work on the tailgate, there's a piece of paper put in there just behind the removable panel. Often times, those get removed when someone works on the tailgate and they never get replaced.
Without that paper or something else in there to deflect the water getting into the tailgate as it pours down the window, the water can run right inside the rear of the cab and can even run as far forward as the driver/passenger seats. I have this problem currently with my '90 and I need to get it fixed before rust gets a foothold inside the rear cab.
That's likely the reason for all that rust developing on the inside. :whiteflag
89 Problems
Hmmmm... I didn't know that! My tailgate doesn't have the paper, but it also doesn't have a bottom... I was wondering how stuff near the front seat was getting wet. I figured the water would just run out the bottom and outside.
You wouldn't have a pic of that?
Steve does... but his SuperMotors is so full of other crap.
I think I ran across it when I was looking at his "Tailgate Tech" stuff when I was repairing my spring bar that popped out of the bracket.
The paper is held on with the black, sticky, body panel goop, mainly at the top. They usually look like crap, from water stains... but they survive it pretty well to do the job. It's very easy to assume it's nothing and rip it off to get it out of the way and never give it a second thought.
I'm thinking of replacing mine with some 5 mil plastic I have left over from another project.
sorry for the hijack MONGO.
Discussion Starter #80
No problem, we're all learning something about it!:thumbup I was sure the rust was from water making it into the rear of the Bronco but had no idea this piece of paper was so important! I know Patches doesn't have one! The other thing is this spring that I keep hearing about? Is there an assist spring in the gate? I have a bracket bolted to the passenger side jam that I have no idea what its there for, could it be remnants of the assist spring? Picture would be great on these two subjects!
