Proof positive that we do think alike, if you look at the pictures you can make out 4 mounting tabs on the overhead and 10 mounting tabs for the center consoles! I made them to be sure I could remove them! I took 1" angle and cut it into 1.5" lengths. Drilled it and the aforementioned parts, bolted the mount tabs to the piece to be mounted then held the pieces in place while I tack welded the tabs to the tub of the Bronco. Then removed the piece and welded the mount tabs in fully! They are all removable!
