i pulled and replaced the e40d to a c6 and its all bolted in. i just have the driveshafts to do and i need to wire it up and figures something out with the linkage.
soo question 1, i have two harnesses that were plugged into the e40d a white one and, a black one and theres 4 wires on the c6 does anyone know which wires i need to hook to the c6?
question 2, the e40d is alot longer than the c6, soo the linkage is way off. is there anyway to modify it to make it work or do i just need to hunt down the right linkage?
question 3, the stock crossmember has a 6 inch gap from it to the trans and im not soo sure making a spacer and sticking it in there would work to well. has anyone tried to modify this or should i just go look for the c6 crossmember?
thanks in advance for any help
