i am wanting to get as much power out of my 302 without having to replace anything or buying anything. just like a tune up, what could i do to make my 5.0 faster?
what could i tune up
air box?
intake?
throttle bodies?
To make an extremely powerfull motor, you need some ******* engineering...I would suggest the following on the *cheap*
First off, get rid of that restrictive intake, just take all of the airbox and tube assembly off. Loose all the emissions and the like. Next, if you wanna get a *cheap* cold air intake, go to lowes/home depot and get some 90* bends and some straight sections of pvc pipe. Make sure to get the intake part of the setup as close to the road as possible, about 4-5 inches off the ground is perfect....No filter, that restricts it. For better flow out of the exhaust, I would also recomend that you cut it off right before your first cat, or if you want maximum flow, make sure to cut the exhaust right after the manifolds (chicks dig obnoxisly loud exhausts)
That and make sure to loose all the weight you can. Take out things that YOU dont need. Such as: carpet, extra seats, ac, power windows, power locks, radio, speakers, spare tire, tools, etc...
Then youll have the bestest fastest Bko in the WORLD!!!
P.S. This wouldn't be roman's cuzin would it?
