41 - 43 of 43 Posts
Pepe' have your tried going the other way in which you would bolt the mount to the engine while installing, instead of the frame? 1-1/2 is a lot though. I have their extreme 429/460 mounts in my 78, no issues there.
Mounts were bolted up to the block before I tried to install. Dad was trying to convince me to do it the way your talking, after we couldn't get it to fit. Probably a better explanation in the thread.
I checked JBG and there are NO mounts listed for a 400 but one set listed for a 351M in the early 80's. I'm going to try and pull these and see if I can swap 'em around... even if I have to grind 'em up, before I try those. Apparently I love the punishment. ;)
Since the extreme motor mounts use a leaf spring bushing and are bolted together I took them apart during install. IIRC I bolted one half to the engine block and then shimmied the other half in while the engine was jacked up.
1996 Bronco 5.0/E4OD/BW1356
that's an interesting idea...
It totally works! I've been doing it for years, I've even got a set of those "extreme motor mounts" on my shelf because they didn't work in my EB with my bigger motor, so I just ended up bolting the motor mounts together from there on out. The nut came loose once so I weld them now.
165115
165116
Reactions: dash_cam
41 - 43 of 43 Posts
