I would like to see that. Do you know where the thread is at?Are you set on mounting it to the outside?
There are guys on here that have made some slick inside mounts.
One I remember that sits sideways and bolts to the bottom back of the rear bench seat. It looked great.
True, but if it is mounted like that wouldn't it be up when the seat is folded forward?The problem with the one at the bottom of the rear seat is if you are packed up with whatever, you will have to unload everything to get it. I have seen one guy here mount it under his hood above the engine.
That's where I went with. Seemed like otherwise dead space especially after the roll cage.My second option would be the interior along the side in back.
i think that was HuggyBI have seen one guy here mount it under his hood above the engine.
It was :toothlessi think that was HuggyB
It sticks up waiting to catch on stuff. I want it tucked away. I'm seeing a lot of put it inside. But no issues with mounting it on the hood?To the OP, what is the issues you have with mounting off the tire rack? I have mine that way and no issues. Releated to wheel weights?
I really like this one, but i might be a little biased.:toothlessAsk and you shall receive
http://www.fullsizebronco.com/forum/showthread.php?t=123322
