Some times I go start my 93 Bronco and its like the battery's dead nothing comes on but I move the shift lever a little bit and everything comes on and it starts. What would cause that?
The MLPS won't interfere with anything but cranking - if you have NO power until you jiggle the shifter, you have a problem at the ignition switch (pink pointer).arnoldwiltz said:...its like the battery's dead ...but I move the shift lever a little bit and everything comes on...
Hi Steve.....I dont want to sound like a jerk, but exactly what is a logic table? I just looked in the back of my Haynes, and didnt see anything with that title???Steve83 said:
Thanks, and Yes I have the light blue one.........and it was exactly where you said it would be. They have quite a bit of quality info in there!Steve83 said:If you have the light blue cover, it's on p.12-8, figure 10.4b. It's not set up like a "table", but it still qualifies. If you want to see one that IS set up right, flip to p.12-10, figure 11.1; they call it a "continuity chart".
